01-09-2014 11:40 AM
Can anyone help with information about XP4/XJ4 connectors for PXIe: Suitable vendor type numbers?
We want to make a custom card to plug into a PXIe-1071 chassis - but only need the 3.3V power from the chassis. But after long search I was unable to find a type number for such a connector. XJ4 is the smallest but obviously any of the connector types will do as they all have power pins.
Solved! Go to Solution.
01-13-2014 04:01 AM
Hello heel.
I have searched in our internal papers, and according to my findings we are using ERNI as a manyfactor for our connectors.
Also, since you want to design for own PXI board, you might be able to find some usefull information in the PXI specifications.
I hope you can use this information.
01-13-2014 04:06 AM
Thanks Alex,
Your information is very appreciated.
01-13-2014 04:07 AM
Glad I could help ![]()
02-14-2018 08:24 AM
We are about to make some PXIe to PCIe adapters but after checking with ERNI, TE Connect and many other (Googling, etc..), i haven't been able to find a XP4 connector that is right-angled. ERNI only have vertical connector that fits on a real PXIe chassis backplane which won't fit for simple straight pcb PXIe to PCIe.
Any hints for such connector ?
See image of similar PXI to PCI adapter that we want to reproduce for PXIe...
