PXI
When the next sampling clock comes, the DAQmx writing is not completed; it indicates that the user program can not keep up with the hardware clock.
hello, everyone. I have connected the AMESim model at the rate of 1000hz to the AO0 of PXIe-6366, the AO rate of PXIe-6366 is the default value, then I tried to deploy the project, but it seems that the software rate is too low. the details are as follows:
there are some message of the log:
Details:
Error -209801 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
Please slow down the hardware clock or modify the user program to keep up with the hardware clock.
but how to change the hardware clock, like pxie-6366?
(2,916 Views)
ok,thank you carmen9 , I will look it carefully
but I only use Veristand 2014 instead of labVIEW, so there is no VI.
thanks again
(2,888 Views)
