PXI
When I connect a NI PXIe-1071 to my PC, the PC doesn't start.
I have a NI PXIe-1071 chassis but when I connect it to my PC the PC doesn't start.
Can anyone help me?
Thank you,
(6,255 Views)
How do you connect the pc to the PXIe chassis? Do you have a MXI-PXIe connection or do you have a Real Time controller inserted in to the chassis and connected to the pc by ethernet connection? Please describe as well as you can the hardware configuration of your system....
(6,235 Views)
My system is composed by:
1 NI PCIe-8361 (inside the PC)
1 NI PCIe-1071 (chassis)
1 NI PCIe-8360 (to communicate with the PC)
1 NI PCIe-4498
1 NI PCIe-6514
If I connect the system to another PC it works, so I think I have a problem with BIOS. Now I try to change something in the BIOS settings.
Thank you
(6,221 Views)
It was a BIOS problem!
I solved the problem using:
http://joule.ni.com/nidu/cds/view/p/id/2759/lang/en
Thank you
(6,218 Views)
i am facing the same issue like you were. unfortunately the bios problem solution is not available now. could you please help me with it.
thanks in advance
imanka
(2,329 Views)
Hello Imanka,
I don't remember exactly but I think I've used an "NI MXIe BIOS Compatibility software",
Take a look at this page:
https://www.ni.com/en/support/documentation/compatibility/17/mxi-express-products-and-mxi-express-bi...
Best regards, ciao,
nik,
(2,306 Views)
