PXI
Visual Studio 2017 in NI PXI 1042 (Windows)
Hi
How can I install Visual Studio 2017 Pro in NI PXI 1042 (Windows) ??
According to the Microsoft, for activation, internet connectivity is required.
And I do not know whether I can connect to the internet with NI PXI 1042 (Windows)
Any help ??
(2,238 Views)
You can install any Windows program on your PXI chassis. You should be able to treat a Windows PXI controller just like any other Windows PC. Depending on the controller you are using, you should be able to connect to a network directly from the Ethernet port on the controller in order to connect to the internet.
Matthew C
AE | NI
(2,205 Views)
