06-22-2010 04:52 AM
Hi ,
i have a pci board using PLX's PCI9052, for which we had a driver developed in C++..
we usually used to communicate to this driver using a DLL that was also built in C++
thing is that when a single read or write transaction happens thru labview it hardly takes 3.7us to 4us delay between
each read or write
LabView ---- > C++DLL ----> C++ Driver ---> Hardware (yields 3.7uS read to read time)
But if i use VISA driver development kit to generate driver the delay increases
LabView ----> VISA Resource name ---> Hardware
though the latter path seems bit short then delay is as high as 12uS
i thought that VISA would be faster than C++ DLL ..
any ideas as how to use VISA driver to optain maximum speed ?
06-22-2010 07:42 AM
If you're accessing memory-mapped registers on your device (i.e., device registers that share the global system address space), consider using viMapAddress and viPeek/viPoke. The viPeek/viPoke operations will access HW directly for a PCI device, bypassing the various layers of software in between.
The flow of your application would look something like this:
ViOpen(PCI device resource) --> viMapAddress(address range for registers you want to access) --> viPeek/viPoke(register offset) --> viUnmapAddress --> viClose
As mentioned previously, this IO access method will only optimize memory-mapped register accesses. If you're performing PCI configuration cycles, it won't help.
Eric G.
National Instruments R&D
06-22-2010 11:10 PM
Hi
I am using IO address range and not the memory address range,
in that case what should i do....
any ways to improve access speeds for single reads and writes..
06-23-2010 07:51 AM
Hmm, unfortunately I don't think there's much you can do to optimize IO space reads and writes using NI-VISA. The function call stack for an IO port write using VISA looks something like this:
LabVIEW --> NI-VISA (user mode) --> NI-VISA (kernel mode) --> HW
It looks like NI-VISA is adding some extra overhead compared to using LabVIEW's direct IO access feature (possibly as a result of the user-->kernel transition, which can be a relatively time consuming operation).
On a slightly-related note: If you have the ability to modify this board's HW design, it would be best to use memory space instead of IO space. IO space is a legacy resource, and some systems have a difficult time configuring PCI devices that request IO space instead of memory space.
Eric G.
06-23-2010 11:12 PM
Hi Eric
thanks for spending time
i will try changing my brd's I/O map to memory map,
let me see the performance
