PXI
Virtual PC(VBox) - without PCI passthrough (PCI-MIO-16E-1)
I have a problem with using PCI-MIO-16E-1 on virtual PC (host W10, Guest XP SP3). I cant use PCI pass through because VBox is not supporting it. Hyper-V is supporting it only on Server version of windows. So main problem is that i cant access physical channels of PCI card in LabView.What i tried is using remote system - VISA (i can see card in remote system, i can even open session to it), but Lab View couldn't see any physical channels.
So i think i have some options.
1. Try to make remote system working. But i think that its not possible.
2. Find replacement for PCI card to something which can be connected through serial port or bus.
Thanks for any suggestions.
(1,295 Views)
This article will explain better - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAiJSAW
Santhosh
Soliton Technologies
(1,278 Views)
