PXI
Video Monitor for PXI Chassis
What does everyone use for a video monitor with the PXI Chassis NI PXIe-1085  with the embedded controller PXIe-8822?  Do you just use a computer monitor or does NI sell a monitor that can be mounted in a rack?
(926 Views)
Use a regular monitor with DisplayPort or get a DP to HDMI/VGA adapter to match your monitor.
Is the monitor mounted inside the 19" rack? If so, several monitors are used for data centers that fit in a 19" rack.
Rack-mount items tend to be on the higher end of the price spectrum. For example, you can get a Dell or HP 27" monitor for ~$150, whereas a rack-mount one could be ~$1k or higher.
Santhosh
Soliton Technologies
(897 Views)
