PXI
Veristand2020 PXI Machine
I have an connected error while I was deploying the model. Also, target is refused connection. I use real time target PXIe 8101 and OS is Linux RT.
How can I solve this issue? Thank you.
Deployment Error
Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
<append>=========================
NI VeriStand: Open VI Reference in DAQ Engine.lvlib:Call Init VI.vi->DAQ Engine.lvlib:Create Virtual Channels DIDO.vi->DAQ Engine.lvlib:DAQ_Init Devices.vi->NI VeriStand Engine.lvlib:Initialize DAQ Data.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi<APPEND>
VI Path: <b>c:\ni-rt\NIVeriStand\DAQ Plugins\DAQPlugins.llb\DO.vi</b>
Built Application or Shared Library (DLL): Make sure all dynamically loaded VIs were properly included in the build specification for the application or shared library.
LabVIEW Real-Time: VIs built into executables cannot be accessed through VI Server calls. Use Source Distributions to dynamically call VIs on Real-Time targets.
Error 7 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
VI Path: c:\ni-rt\NIVeriStand\DAQ Plugins\DAQPlugins.llb\DO.vi
(659 Views)
PXIe-8101 does not support Linux RT. Only PXIe-88xx supports Linux RT.
Reference: Provisioning a Controller to the NI Linux Real-Time Operating System
(594 Views)
I am so sorry, I didin't check the LV. OS is PharLap. There is a new issue 0x3F. How can I solve this?
Deployment Error
NI VeriStand: Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
NI VeriStand: Error 63 occurred at TCP Open Connection in Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
Possible reason(s):
LabVIEW: (Hex 0x3F) Serial port receive buffer overflow.
LabVIEW: (Hex 0x3F) The network connection was refused by the server.
Target: 192.168.2.155
Error -307853 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
NI VeriStand: The VeriStand Gateway was unable to establish a connection with the target. Confirm that the target is running and that the VeriStand Engine successfully has started. If you still cannot connect to the target, use MAX to reinstall the NI VeriStand Run-Time Engine to the target.
Possible reason(s):
(584 Views)
(573 Views)
I've already downloaded the Veristand Real Time Engine Tools but it doesn't working still.
(569 Views)
Try deploying an empty project and see if it works.
If it doesn't work, the VeriStand Engine is still not running.
(562 Views)
Accepted by topic author ikeser@makersan.com
Yeah, I solved the problem startup VI was off. I opened it and veristand connected
(505 Views)
