PXI
VSA, VSG attenuator
Dear All,
I am little bit have confusion about the attenuator of the VSA and VSG and how to set that in the LabVIEW code.
there is a function called (Attenuator hold) which I enable it, but as I know the attenuator value for the VSA and VSG should be set for a specific value. I am not sure how and where can I set that value.
Is there any of you have an idea how to mange that, and what would happen if the attenuator value is not being set.
Thank you
best regards
Thoalfukar
Message 1 of 1
(2,325 Views)
