PXI
VI for PXI 6052E with SCXI 1140
I am novice at LabVIEW and I am in deep need for some guidance. I have got a PXI/SCXI system that I intend to use as a multi-channel oscilloscope. I have got eight SCXI 1140 cards along with one PXI 6052E, all sitting in a PXI-SCXI combination chassis (PXI-1011), and they are being controlled by an NI 8174 controller. All the hardware has been installed properly and NI-DAQ detects everything fine. Now I want to write a VI (I have got NI-DAQ 6.9.1 and LabVIEW 6i) that will allow me to monitor my 64 anolog inputs just like in a 64 channel oscilloscope. I know that the gain on the SCXI is set manually. The reason I went with the SCXI 1140 was to have no skew time and also have differential inputs. I intend to measure 64 signals in a range
of +/-100 mV at an effective sampling rate of 5KHz (for each channel)with the highest resolution possible. If you could give me any suggestion about how to write a VI for this application, I would really appreciate it. Thank you!
(3,433 Views)
I would recommend to take a look at the LV shipping examples. There are two of them that fit what you are looking for. The first one is called SCXI-1140 Phase Difference and the other one is called Cintinuous Acquisition & Graph (Buffered).
The general scheme that you need to follow is:
AI Config VI (here you will specify your channel list)>>AI Start>>AI Read (in a loop)>>AI Clear>>Error Handler.
For more programming ideas, I recommend to visit ni.com and make a search on the specific topic that you are looking for. NI offeres Knowledge Bases, Example Programs and Tutorials that help customers develop their applications.
Good luck!
(3,433 Views)
Thank you very much for your help!
(3,433 Views)
