12-24-2020 10:54 AM
Hello, i want to use TDMS to store the data generated from a PXI. I was checking the examples provided by Labwindows/CVI, but i only found examples related to DAQ device !? Why there is no examples for other PXIs like (DMM). So if i want to store a data in a TDMS generated from PXI 4065 which is a digital multimiter (DMM) ? Is it possible or TDMS only for DAQ device.
so to configure TDMS file logging for the task, there is specific function for that for example:
// DAQmx TDMS Configure Code
DAQmxErrChk(DAQmxConfigureLogging(taskHandle,TDMSfilePath,DAQmx_Val_LogAndRead,"GroupName",DAQmx_Val_OpenOrCreate));
Is there any other functions for DMM to configure TDMS ,
12-24-2020 05:39 PM
The streaming to a TDMS file is a function of DAQmx. But you can still read data from whatever and write that data to a TDMS file using whatever TDMS API is available in CVI.
12-25-2020 12:30 AM
I understand. Thank you for your quick response.
