07-31-2019 03:22 AM
Hi every on
I'm using PXIe-1062 chassiss + Real-Time PXI controller
Can I use PXIe-8234 dual poGigabit Ethernet Interface as a Master EtherCAT?
07-31-2019 03:50 AM
I am afraid that you can't use the PXIe-8234 as the EtherCAT Master. Thanks!
07-31-2019 04:27 AM - edited 07-31-2019 04:48 AM
Thanks for your reply.
There is an another option for us. based on this link (http://www.ni.com/product-documentation/54598/en/#toc2) we can use PXI-8234 in a Ring topology. actually I doubt this NI recommendation.
Is it possible or Not?
I know that PXI-8234 is not mentioned in NI-Industrial Communications for EtherCAT® 19.0 Readme file (reference: http://www.ni.com/pdf/manuals/374786l.html)
07-31-2019 07:53 PM
Hi M.Javad,
Embedded Real-Time Controllers with three or more Ethernet ports can be used as a Ring topology. So, the PXI-8234 can be used in the Ring topology.
Thanks!
