Hi!
I have 2 x PXI-8430/16 modules (https://www.ni.com/en-no/shop/select/pxi-serial-interface-module)
with 2 x serial cables (http://www.ni.com/en-no/shop/select/serial-cable?skuId=47906) connected to each.
I need to have the serial cables placed approx. 10m away from PXI modules, and have searched "everywhere"
for extension cables, without any luck...
The only cables I've found at NI are these: SHC68-68-EPM (http://www.ni.com/en-no/shop/select/multifunction-cable?modelId=124245)
with VHDCI male to D-SUB female.
What I need, is 4 x approx. 10m long extension cables with VHDCI male/female connectors,
and/or some kind of adapters/adapter cables/gender changers to "make" these cables from mixing other cables/adapters.
Any help would be VERY much appreciated!!
