I have a PXIe-1085 12 GB/s providing a maximum nominal single-direction bandwidth per slot of 4 GB/s.
Then I have a FlexRIO 7976R 3.2 GB/s on slot 4.
I use FIFOs to communicate between Host controller and FPGA.
In the worst case of my application I have a throughput from Host to FPGA of 262 MB/s and a throughput from FPGA to Host of 2.88 GB/s.
Hence, the total throughput is 3.142 GB/s that is less than 3.2 GB/s.
In this condition I have an undesired behaviour with loss of data.
If I reduce the input througput from Host, the output throughput also decreases and everything works well.
I have also also controls and indicators in my FPGA loop that are read/written each iteration (180 MHz).
But from Host I don't read/write from/to these controls/indicators during FIFOs transfer.
My question is:
In the throughput calculation, should I consider even the writings/readings of FPGA controls/indicators that are not used from Host?
Thank you!
