PXI
The precision measurement temperature with help PXI-4071
I  consider the variant of the measurement temperature with help PXI-4071.
It is required the precision of measurement.
I found into the specification the RTD with accuracy 0.14 and Termistor with accuracy 0.08.
If I will use the termistor. What kind of termistor I have to use ?
If I will use RTD. Pt3851 RTD - is this type of resistance ? Where can I find that resistance ?
May be is the article about using the mode of temperature measument ?
Anybody used that method ?
Thanks for advance!
(2,936 Views)
Hi MaxiMuz,
According with the PXI-4071 specifications, you can use a thermistor in the range of -80 to 150 °C.
The pt stands for platinum and 3851 is the resistance at 0 °C in Ohms.
Jos'e F.
(2,903 Views)
Do you mean, at 0°C its R=3851Ohm  ?
(2,897 Views)
Yes, that is right.
Jose
(2,890 Views)
