09-28-2011 03:30 PM
I am trying to use the LabView VIs that come with SysMon 1.1.1. I have been able to get the Monitor Fans, Monitor Voltage, and Montior Temperature VIs to work. They all deal with the chassis and the address defaults to PXI0::1.
I get an error "-25001 occurred at Property Node" when I use the Monitor CPU. The System Controller Resource Name is set to "localhost" I have a PXIe-8133 controller.
Does MAX have anything to do with the Resource name? Does "localhost" need to be setup in MAX? If so where?
I also get this error using LabWindows' NiSysMon_OpenSession.
Solved! Go to Solution.
09-29-2011 10:08 AM
Hi Paul,
The reason you are getting this error with the controller related VI's is because your PXIe-8133 is not supported by System Monitor. In the readme for SysMon, you'll find a complete list of the controllers and chassis' supported by this API. I've listed them below for you.
Supported chassis:
Supported controllers:
Kind Regards,
09-29-2011 10:51 AM
I read the readme this morning and saw that the 8133 is not supported.
Why is the newest CPU not support?
09-30-2011 09:06 AM
Hi again Paul,
I imagine the latest System Monitor API came out before the 8133 controller. Unfortunately, there hasn't been a new version of SysMon since.
09-30-2011 09:28 AM
11-04-2011 01:35 PM
Please vote for this at:
Thanks.
