04-08-2013 02:47 PM
I am new to labview and have a project that I have taken over from someone else. It is a split Hopkins pressure bar if you want to look it up, but the basic ideas is that I have 2 strain gages connected to a 4330 block on a PXI-1082. They are both in quarter-bridge configs and display and log data independently, but I need to collect the data from both sources simultaneously and they have to be synchronized.
I just can't make it work. I have tried VIs with the tasks for each in both parallel and serial structures, one clock task and two. I have been trying to modify examples and code from posts but I just don't understand labview well enough to understand what is going on or how to recreate some of the elements in the examples.
Any help is greatly appreciated.
04-09-2013 01:43 PM
Hello spkirby,
Can you explain in more detail how things are not working during your acquisition? Are you receiveing any errors. is your timing off? Here are a couple of links that should help you get started with making acquisition code in LabVIEW as well as Synchronization.
http://www.ni.com/white-paper/5370/en
http://www.ni.com/white-paper/4322/en
I hope this information is useful!
-Travis E
