PXI
Reply
Synchronizing AI and AO task on PXI-4461
I just start to use this PXI-4461. I have problem about signal synchronization. it is between AI and AO channel on PXI-4461. In general, I generate DC signal (the VI I took from the forum) and acquire after passing a Resistor.
Here I attached the VI and its picture. The problem is after adjusting the value on AO channel, the AI channel shows delaying of acquisition. Perhaps it is normal, but I am not sure.
Do you have some advice for this problem?
I really appreciate your help.
(125 Views)
Re: Synchronizing AI and AO task on PXI-4461
Could you attach SyncbetweenAIandAO_DSA.vi again?
I cannot see its block diagram now.
(101 Views)
