05-29-2019 09:15 AM
The system setup is:
1. PXI-1033 chassis
2. Slot 2 - PXI-4462(DAS)
Slot 3 - PXI-5412 (AWG)
Slot 4 - PXI-4472 (DAS)
We are measuring 5Hz - 25kHz. We are particularly interested in the phase difference between the 4462 & 4472 measurements.
I need to synchronize the 4462 & 4472. Is this possible with this setup? My understanding is that the PXI Chassis 10MHz clock must be used for both te 4462 & 4472 and the Star Trigger is also required. I think I read that the DAS must be both in slave mode for this to work. How could I accomplish this? Is there a labview DAQmx example available? thanks
05-29-2019 07:07 PM
Hello davidhi,
I am not entirely certain if this will solve your problem, but this page (http://www.ni.com/product-documentation/11369/en/) has a lot of good information on synchronizing DAQmx events via clock synchronization and designating master/slave tasks. Figure 8, for instance, might be of help.
Best of luck!
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
