PXI
Stepper motor moving at 0 velocity every 16,4 seconds
I am not sure if this is a new development or we just never noticed it since 1 step is difficult noticed.  But just recently we had a strain gauge mounted to a stage and instead sending a halt command to stop we sent a zero velocity command.  We noticed a periodic noise coming from the sensor, which lead us to investigate the stage and that is when we noticed that the sensor was picking up the 1 step movement of the stage.  I am able to replicate behavior in NI Measurement and Automation using the 1D-Interaction control.  Set it to velocity mode, with a velocity of either 0 steps per second or rpm, press start.  Both the position count and position plot will display a 1 step movement.
Message 11 of 14
(913 Views)
Based on the specifications of the device (http://www.ni.com/download/labview-development-system-2017-sp1/7099/en/), a velocity command of 0 steps/s is actually unsupported. The velocity range (p. A-2) is 1 to 8,000,000 steps/s. The recommendation is to use the stop command.
Brian.D
NI Product Owner
VeriStand
Message 12 of 14
(904 Views)
Actually the problem was observed to occur even with a non-zero velocity. We saw a one step increase following a certain time, and recurrent. Thus, we tried with a zero velocity and observe it more clearly, but the problem does not come from the fact that the velocity was set to 0.
JV
Message 13 of 14
(840 Views)
Just to clarify, even with a non-zero velocity, you are consistently observing a jump of 1 step every 16.4 seconds? Is this with a relatively low velocity?
Brian.D
NI Product Owner
VeriStand
Message 14 of 14
(817 Views)
