PXI
Status Error Code -50400, PXI 4461
Hi all,
I am using NI PXI-4461 for testing. But suddenly today our labview program stops working now with a status code -50400, which says 'The transfer did not complete within the timeout period or within the specified number or retries.' I could not find the meaning of this status code. I do need your help.
Any thoughts will be appreciated.
Steve
(1,509 Views)
Accepted by topic author xzzgameboy
Since the error -50400 occurred during self-test, I would consider it as the instrument did not respond back within the required timeout.
Suggested troubleshooting options,
  • Reset, Self-test, self-calibrate
  • Power cycle the PXI system
  • Move the 4461 to a different slot
If the module is still not functional after these, it could be just a case of a damaged/bricked instrument that needs repair by NI.
Santhosh
Soliton Technologies
(1,469 Views)
Thanks!!!!
I did reboot the system and the second time somehow this error went away.
Not sure what caused this issue but now the system is working properly.
Thanks again!
(1,467 Views)
Hi santo_13, today I had the same problem but in my case there was an error also for resetting (pict attached). I repeated the same steps in another slot and with a new board.
Do you have other suggestions?
Thank you
(936 Views)
