PXI
Single process shared variable w/o (without) FIFO between deterministic loop.
Why can't we use single process shared variable without FIFO for communicating between deterministic loop?  In other words, why it's always recommended to use FIFO for communications between deterministic loops?
Ajay.
Ajay MV
(5,480 Views)
Jitter.  When using non-FIFO communications, you introduce jitter into the system, making your deterministic loop not so deterministic.
(5,475 Views)
And.. Why that's so?  Why there is such jitter causing variable available?  We could always use variable with FIFO if the other non-FIFO vairable causes jitter, isn't it?  Is there any overheads in using non-FIFO variables when compared to FIFO variables?
Ajay.
Ajay MV
(5,470 Views)
Accepted by topic author Ajay_MV
It's called resource sharing.  When using a single process shared variable, only one thread can access it at a time.  So what happens is A tries to read, but B is busy writing to it.  So A has to wait, adding jitter.
With the RT FIFO enabled, you don't have this issue.  A can read from the FIFO at the same time that B is adding another element.
(5,468 Views)
Thanks for the clarification 🙂
Ajay MV
(5,465 Views)
