PXI
Sev 1- Need help in choosing alternative Switch matrix card for PXI 2535
Hi Team,
We are using NISTS T1 tester for one of our customers and the tester config includes 4 Switch matrix card PXI 2535 4x136, Moving forward If customer wants to upgrade or purchase NISTS T1 M2, Can we still use 2535 switch matrix card (4 cards) or is there any other better option?
We had gone through the PXIe 2531 spec but found these are the relay not the FET based switch like PXI 2535. In case if we would like to use 2531 what kind of additional circuitry required?
Please suggest us.
Best Regards
Manasa M
(595 Views)
There shouldn't be any issue if the card and pogo cable are available for T1 M1 and it should be available and compatible for T1 M2.
If 2535 works for your use case, I would recommend staying with that configuration rather than adopting unnecessary changes.
Santhosh
Soliton Technologies
(555 Views)
