PXI
Serial communications with pxi6552
I am using the PXi6552 to communicate with a device via the I2c and SPI. I use the I2C/SPI Digital Waveform Reference Library.
My device use also a serial link (Rs232) and i would like communicate to the device via the serial link (via the pxi6552).
I am searching some examples ( serial via pxi6552) or if possible a library for serial link like I²c /Spi (including protocol: bit start/stop/parity..).
Thanks for your support.
Best regards.
(4,542 Views)
Honestly, I'd just buy a PXI-8430/2.
GCentral
(4,540 Views)
I cannot use the pxi8430, because my device use the same inputs (pins) between the i²c and the serial (+2 config pins).
The goal of the tools is communicate by I²C and after communicate via serial without external action ( no  need to deplug the serial or the I2c plug).
BR
(4,535 Views)
I haven't found such a thing. I think that you'll have to design it yourself.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(4,525 Views)
Lab-user, what you want to do can be done with a FTDI USB module. The FT4232 can interface with I2C and serial like RS-232 (TTL level) With some extra components to switch between the two.
Kees
(4,516 Views)
