PXI
Seeking Windows 11 compatible replacement for PXIe-8135
I have a PXIe-8135 running in a PXIe-1082 chassis along with a pair of PXIe-6368s and a PXI-5412.  I need to plan for a replacement for the PXIe-8135 that is Windows 11 compatible, and am hoping there will be something I can drop into the 1082 chassis to work with my 6368s and 5412 so I don't have to replace anything more than just the 8135.  Can anyone advise on a Windows 11 compatible replacement for the 8135 that would work withmy chassis?
Thanks.
(2,540 Views)
Accepted by topic author bam159
To run Windows 11, you need the TPM2.0 module on the controller.
Based on this article, I would assume 8881, 8862, 8842, and 8822 are compatible (confirmed by this page by filtering for Windows11)
5412 is your risk here as there is no supported driver for Windows11
Santhosh
Soliton Technologies
(2,518 Views)
Thank you @Santo_13.
(2,514 Views)
