PXI
SCXI part is not detected in NI MAX
I have combo chassis 1050 with DMM 4070 placed on the last position to communicate with SCXI module through D9 connector to PXI-1357
my issue is that all the PXI are detected into NI MAX but not the SCXI module (1127 and 1166 ), when i add them manually and make a reset or test i get an error saying the device offline
I tried the same computer with another system (an old system that I had exactly the same configuration ) and it worked which means the driver was correctly installed
could you please help me to identify which part (hardware) you think is defective ( PXI-1357 , SCXI module , 1127 and 1166 )
i also checked the voltage 120 AC and the fuse all are good
thank you for the help
(1,760 Views)
Have you upgraded your driver?
SCXI driver support was dropped in NI-DAQmx 19.1 and later:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z00000159pgSAA&l=en-US
(1,748 Views)
thank you Marshallg for the answer yes the drivers are good
i tried this computer with another station and it works .. i think it s more from the hardware side
(1,725 Views)
