07-29-2009 09:29 AM
Hello
I use a SMU board and have programmed an application in C#. It runs fine.
When I tried to run DCpower Soft Front Panel while I was running my application, I got an error said that the device has already been in used.
Is this because of a safety issue that I can not run Soft Front Panel and an application for one SUM board at the same time?
Is there any way run both at the same time so that I don’t have to use other device (ie DMMs or handy voltmeters) to test?
I have noticed that I can run Switch Soft Front Panel and an application which uses a switch board at the same time.
07-30-2009 07:03 PM
As you already witnessed, when you have an application that has an open session of the SMU, this reserves the resource and prevents any other program from accessing it. I would imagine there is more risk to having more than one application controlling an SMU than a relay. Keep in mind that the Switch Soft Front Panel (SFP) enables you to monitor connections on a switch module as you make them, making the Switch SFP a debugging tool, when used with an open session.
Glenn
