PXI
Route PXI trigger (PXI_Trig0) across the PXIe-1085 chassis and thru the PXIe-6674T using .NET (C#, VB.NET, C++)
I am looking for some .NET examples (C#, VB.NET, or C++) on how to:
  • Configure the Backplane Routing of the NI PXIe-1085 Chassis
  • Configure the Active Routes of the NI PXIe-6674T Timing and Synchronization Module
More Details:
A trigger signal, PXI_Trig0, originates from one of the slots in the PXI chassis.  The trigger needs to be routed across the PXIe-1085 chassis to slot 10.  (i.e. the Backplane Routing needs to be configured by a .NET application.)  Next, the trigger needs to be routed thru the PXIe-6674T to the PFI0 connector. (i.e. the Active Routes needs to be configured by a .NET application.)
I know how to do this using NI-MAX and the PXIe-6674T Test Panel.  I just need to do it in .NET.
Message 1 of 1
(814 Views)
