06-29-2021 08:41 AM
Dears at NI
I am requesting your assistance regarding the following.
I have a DAQ system from your side based on the following hardware
The software for this DAQ is lost so I want to know how to re-use this system for example:
Thank you very much in advance for the support.
Best Regards
06-29-2021 05:42 PM
Correction, though you've addressed your post to NI, but this query will be 99.99% tended by fellow NI product users and we in no way represent NI.
The good news is DAQmx 19.0 supports your SCXI chassis and devices but the bad news is starting 19.1 support was dropped.
This means you can install this even on a Win10 PC with DAQmx 19.0, accompanied with LabVIEW 2019 and other 19 versions of drivers. Out of the HW you've listed, 4065 DMM would require calibration.
In order to communicate with the SCXI system, you need a PCI-DAQ control card, do you also have it? and is the DMM USB based?
I am completely new to SCXI and guiding you based on my extensive experience with PXI products and going by articles published by NI. Some articles I would recommend you to read to familiarize yourself about the hardware you've,
Getting started with SCXI - https://www.ni.com/pdf/manuals/320515f.pdf
SCXI Chassis user manual - https://www.ni.com/pdf/manuals/374423l.pdf
SCXI Switch modules getting started - https://www.apexwaves.com/pdf/manuals/PXI-1010/ni-switches-getting-started-guide-for-ni-scxi-switch-...
06-30-2021 12:38 AM
Thank you very much for the reply, my DMM is a card connected directly to the motherboard and the system is already working so I think it's complete.
