PXI
Reuse of .lvbitx file in different PCs
I have a doubt regarding PXI 7841R. Can I reuse a .lvbitx file which was generated for a 7841R from the first PC to second PC which is having the same 7841R PXI card. I am currently using a dll to access this lvbitx file in the first PC. I want to use the same dll file and the .lvbitx file in the second PC.
Please let me know if it is possible.
Thanks in Advance!!
(2,613 Views)
I don't see why not.  I've worked with similar boards, built the lit file on a development computer and used on several test systems.
Are you having issues?
(2,599 Views)
The .lvbitx file is for the instrument/card and not linked to the PC. You can use it on as many 7841R as possible, this is like the firmware for a microcontroller.
Santhosh
Soliton Technologies
(2,591 Views)
Hi
Thanks for the response.
I have two 7841R cards which is connected to two different PCs . I want to use the .lvbitx file from the first PC in the second PC. When I tried accessing the .lvbitx using the dll generated in the first PC by copying it to second PC, I get error number 63101 saying bit file issue. I tried keeping the .lvbitx in the same path as the previous PC.
PS: I am not accessing the dll directly using labview. I am using vector CANoe to access the dll.
(2,580 Views)
Hi
I got 63101 error (NI error bit file loading issue). I kept the .lvbitx fiile in same path as the development pc.
PS: I am not using Labview to access the dll. I am using vector CANoe to access the dll.
(2,578 Views)
@arun004 wrote:
Hi
Do you have the NI R Series Multifunction RIO Driver installed on the second computer?  If so, is it the same version you have installed on the development computer?
(2,567 Views)
Hi
I had installed Version 17.0.1 in the development PC and Version 21.5 in the second computer. I tried changing the Second computer back to 17.0.1. But still the issue persists.
Let me know if I have to change anything else..
(2,519 Views)
