PXI
Resolution of PXI-6704 in different output ranges
I have a requirement for increasing the voltage resolution of the output from a PXI-6704 card. I don't have direct access to the card at the moment, so can't test this for myself!
The last time I tested my LabVIEW code, I had the voltage output range set to +/-10 V. This meant that I had a resolution of 20 V / 2^16 = 0.3 mV (as it's 16 bit).
Since all of my voltages are in the range 0.40 to 0.46 V, can I adjust the output range to, e.g., +/-1 V, so that my resolution will be 0.03 mV? Or is the voltage resolution independent of voltage range?
Many thanks
(2,292 Views)
Accepted by topic author mrendell
Hi mrendell,
The range is fixed I'm sorry, maybe look at a different DAQ card if you need more resolution.
James
(2,255 Views)
