I have 4 Pxi cards in pxi-1006 chassis, the 3 cards are working fine and the 4th card is recognised by MAX and when I say TestResources the Test gets passed, but when i try to change some voltage from MAX for that device the voltage write is successfull but the output is not seen at the specified pins...can you please let me know whether the card is working fine or not ? Thanks in advance
It's looking like the board is presenting a hardware failure. The best way to go about that is to give NI a call and ask for an RMA number to get the board fixed. Regards Filipe A. Applications Engineer National Instruments
