10-19-2020 05:48 AM
Hello there,
I am fairly new to LabVIEW. I need to test the response of organic transistors by sending a voltage pulse to the transistor gate and record the response to that pulse at the drain. I am using a common source configuration. I also need to specify the parameters of this pulse and be able to easily modify them. I have access to the PXIe-4138 , PXIe-4110, and PXIe-5413. I tried to find an example that does this but I couldn't find any. if there isn't an already built VI, how can I start in building my own?
12-22-2020 11:35 AM
I do not expect there to be ready solutions. However you may start from LV examples if you have the HW in your system.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIKbCAO&l=en-US
