07-27-2021 03:52 AM
Hello
I just upgraded windows from 7 to 10 on PXIe-3975 thats in PXES-2301 Chassis it has 4 DAQmx cards in it and I wonder whats the proper way to configure a setup? Should I start with PXIe-3975 drivers then go to chassis drivers or the other way around?
All I could file is this page: https://www.ni.com/getting-started/set-up-hardware/data-acquisition/pci-pxi
I know its all from ADLink but since they dont have a forum (at least I couldnt find one) I am coming here.
Thank you in advance!
07-27-2021 04:06 AM
Worth noting PXIe-3795 for windows 10 has only one driver and its ADLINK PXI Platform Services Ver 21.02 if it would have windows 7 it would be pretty plain and simple to install all the chipset/gpu etc.
07-27-2021 05:02 PM
It is sad that ADLINK doesn't have a forum or a simpler support method.
Anyway, assuming that things would be similar to how we set up NI stuff, you would start with LabVIEW then the device drivers.
07-28-2021 04:25 AM
So I did. After instalation of all drivers even from third party websites Windows is still unable to recognise one of the two installed devices.
And that one device is that PXES-2301 (I think), heres the device ID: PCI\VEN_144A&DEV_348A&SUBSYS_348A144A&REV_A1
Also I cant find my PXES-2301 in ACE software. Is this possible that they withdraw support for that chassis?
Has anyone ever came across such problem?
