PXI
Problem with simultaneous AI and DO tasks: Error -89137
Hi.
Answer please, before it was possible to adjust the internal reference frequency and is described into NI PXI- 5600 Calibration manual . At this point it is possible to make ? It is possible to further supply the necessary drivers when buy the device?
Thanks!
(3,152 Views)
Hi Trend22,
Could you further clarify your question?  Error -89137 is a DAQ error that can be resolved with the help of the following resources:
Why Do I Get a Resource Error -89317 When Using a Reference Clock with NI-DAQmx Devices?
http://digital.ni.com/public.nsf/allkb/3D99C0ECBCC9FA9C862576E800556235?OpenDocument
Problem with simultaneous AI and DO tasks: Error -89317
http://forums.ni.com/t5/LabVIEW/Problem-with-simultaneous-AI-and-DO-tasks-Error-89137/m-p/3320075
As far as the PXI 5600, this is a downcoverter module most commonly used in the context of a 5660 or 5661 vector signal analyzer.  It uses the RFSA driver, which can be downloaded from ni.com/downloads along with the rest of our drivers.
http://www.ni.com/download/ni-rfsa-15.6/6048/en/
If the above links are not what you are looking for, please further clarify your question - thanks!
Michael Keane
(3,111 Views)
