We have been using NI PXI with NI PXI 5112, 4060, and 2503 (PXI 1000B). We are using NI Scope 3.1 on XP 32 bit.
On a second testbench, we are using same cards but we replaced the 5112 by the 5114 using the same NI Scope 3.1.
On both testbenchs we are using LabView 7.0, TestStand 3.0 and GOOP (Graphic Oriented Object Programming).
The problem is in our test platform, i need to modify some VI's for the NI Scope Class. The problem appear when i initialize the instrument by getting the "instrument driver revision" for example. I know the driver is different for the 5114, it use the new NI DAQmx, whereas the 5112 use the traditionnal DAQ.
I have the following queries:
1. The correct adress in order to use NI PXI 5114 is like " PXI25::14::Instr " ?
2. Where can we modify parameters of NI PXI 5114 in order to fit with NI PXI 5112 ?
3. Are they other things to change?
4. Are there another solutions ?
Thank you.
The NI PXI 5112 is no longer availaible by NI. I found it in some ebay sellers or some other but we already have the hardware now.
Joffrey
