09-19-2009 11:57 AM
09-21-2009 03:31 AM
Hello HF-Walter,
in the user manual you will find the following set of informations:
• If the inhibit switch LED is steady green (not flashing), the chassis is powered on and operating normally.
• If the inhibit switch LED is flashing green, the air-intake temperature as exceeded the chassis operating range.
• If the inhibit switch LED is flashing red, the power supply outputs are not within voltage regulation requirements.
• If the inhibit switch LED is steady red, the system fans or power supply fan has failed. The remaining fans will automatically be driven high.
I think in your case it´s the second bullet. Please check if your fan work fine and is not covered with anything. Also the chassis should not be covered with anything. Did the chassis stay in a warm environment? Please send me your adress and phone number to Jan.Kniewasser@ni.com to clearify the details if we have to replace or repair your power supply.
Best wishes, Jan Kniewasser
09-19-2017 09:56 AM
Hi, my problem is the third bullet. How can i fix that problem?
