PXI
Please advise a set of individually controllable relays.
I need to control 10 relays individually. I have a PXI chassis and 2503 switch, but I'm not able to control relays individually in it (according to its manual, please correct me if I'm wrong). I would like to connect a voltage source and distribute power across elements through controllable relays. Relays should be able to carry up to 100mA (10V) constantly. The relays should not necessarily have a PXI interface. Can anyone advise a suitable hardware please?
(2,534 Views)
Accepted by topic author m@NI_forum
Well, the PXI-2503 is a Multiplexer board.  You are looking for a Relay Switch board.  Just based on what you have stated, I would look at the PXI-2564.
(2,526 Views)
