I need to acquire and stream to disk the status of N.8 digital lines at 100 MHz clock, idest 100MBytes/sec data rate, in continuously mode (without data loss) for five minutes.
According to NI PXIe-6544 specifications, you should be able to achieve typical data streaming rates 400 MB/s for acquisition and 400 MB/s for generation. So, you shouldn't face with any issue from this side.
Does your application provide an host interface communicating with embedded application? If doing so, you may need to design your application according real time guidelines.
Let me know if you need help or additional assistance.
my goal is simply to save all data (without loss) on the local Hard disk at 100Mbytes/sec rate, continuously in the time for 5 minutes at least.
The data processing will be an off-line operation so it is not necessary a more complex architecture, but my concern is the real sustainability of that data flow from NI6544 to the Hard disk.
