10-24-2021 12:45 AM
Dear sir,
Presently i have PXI-1042 to with me but in present market the part status is mature so i have decide to go with the PXIe chassis.
1)Could please recommend PXIe chassis which is better or equivalent to PXI-1042 chassis?
Queries related to PXIe chassis selection:
I have gone through the ni website and shortlisted some PXIe chassis. But i am not able to finalize the chassis due to no clear understanding of certain parameters those are listed below could you please explain those.
Parameters:
1)What is maximum system bandwidth is it the total slots bandwidth or individual slot bandwidth?
2)What is external clocking and how is it useful?
3)How system timing slot work is it necessary to be there on PXIe slot?
4)How the External trigger access works.
Part number | PXI Chassis Type | Slot Count | Maximum System Bandwidth | External Clocking | System Timing Slot | External Trigger Access |
787026-01 | PXI Express | 5 | 2 GB/s | No | No | No |
784782-01 | PXI Express | 9 | 8 GB/s | No | No | No |
784781-01 | PXI Express | 10 | 24 GB/s | No | Yes | No |
786991-01 | PXI Express | 10 | 24 GB/s | Yes | Yes | Yes |
Queries related to PXIe controller selection:
i have shortlisted some embedded controllers but iam not able to finalize because of difficulty in understanding the controller bandwidth.
1)Could you please explain about the controller bandwidth?
Embedded controllers list for the above PXIe chassis:
Model | Part number | Hard Drive Memory Size | Processor Core | Controller OS | Maximum Controller Bandwidth |
PXIe-8821 | 785545-01 | 320 GB | Intel Core i3 | Windows 10 64-bit | 2 GB/s |
PXIe-8821 | 785158-04 | 320 GB | Intel Core i3 | Windows 7 64-bit | 2 GB/s |
PXIe-8821 | 785158-33 | 320 GB | Intel Core i3 | LabVIEW Real-Time (Phar Lap) | 2 GB/s |
PXIe-8821 | 787895-33 | 320 GB | Intel Core i3 | LabVIEW Real-Time (NI Linux Real-Time) | 2 GB/s |
PXIe-8840 | 785782-04 | 250 GB | Intel Core i5 | Windows 7 64-bit | 2 GB/s |
PXIe-8840 | 785782-01 | 250 GB | Intel Core i5 | Windows 10 64-bit | 2 GB/s |
PXIe-8840 | 785782-33 | 250 GB | Intel Core i5 | LabVIEW Real-Time (Phar Lap) | 2 GB/s |
PXIe-8840 | 787893-33 | 250 GB | Intel Core i5 | LabVIEW Real-Time (NI Linux Real-Time) | 2 GB/s |
PXIe-8861 | 785831-33 | 512 GB | Xeon Quad-Core | LabVIEW Real-Time (NI Linux Real-Time) | 16 GB/s |
PXIe-8861 | 785831-01 | 512 GB | Xeon Quad-Core | Windows 10 64-bit | 16 GB/s |
PXIe-8861 | 787567-01 | 512 GB | Xeon Quad-Core | Windows 10 64-bit | 16 GB/s |
3)Could you please suggest right combination of the PXIe chassis and the Embedded controller chassis?
Thanks in advance.
Solved! Go to Solution.
10-24-2021 09:34 AM
There is a bigger catch that you're missing, how about the instruments? are you going to buy new or reuse the ones from PXI?
The issue is that the PXIe chassis comes with a handful of PXI, PXIe and PXIe Hybrid slots. Out of these the old PXI instruments can only be installed in the PXI slots.
For example, if you choose PXIe-1062Q,
Now to answer your questions,
10-25-2021 02:23 AM
Thank you Santhosh for you reply. I have couple of queries based on your reply could you answer.
Hi PXI-1042 chassis and modules are in our counter part and we are developing similar capability here in India with the PXIe chassis. We don't have the PXI chassis & PXI module slots with us. we not looking for PXIe chassis backward compatibility with PXI chassis.
Could you please reply to below queries for selecting new PXIe chassis, embedded /remote controller whose performance is equal to or more than the PXI-1042 chassis.
Queries:
1)What would be your recommendation for a chassis which will be equivalent or more capable than PXI-1024 ?
I found PXIe-1088 is a good fit for our application. Please comment
2)What would be your recommendation for an embedded controller which will be equivalent or more capable than the PXI-8110 controller ? Because PXI-8110 embedded controller is used in the PXI-1042 chassis.
3) What would be your preference in terms of operating system for an embedded controller ?
4)Embedded controller vs remote controller what would be your preference? Any pros and cons between these two approaches ?
5)Regarding placing an order-> Can we place an order online or will raise a PO to NI ?, What would be the Lead Time ? (Note: We are located in India).
10-25-2021 08:54 AM
All the suggestions I have been providing are strictly based on the data you've provided and looking up equivalents online.
What would be your recommendation for a chassis which will be equivalent or more capable than PXI-1042?
Based on all this discussion, I feel that you have little idea about what you want but are not confident enough to select. Since you're going to make a substantial investment I suggest consulting NI Sales about your application and HW selection to ensure you don't make any mistakes.
10-25-2021 09:02 AM
Or a local NI Alliance Partner that has experience building a PXI system.
11-01-2021 05:07 AM
Hi santhosh,
The above reply solved my problems
