09-18-2018 04:27 AM
Hello everyone,
I was working with PXIe-8880 and LabVIEW 2016. I had a problem with UDP communication protocol.
My program works correctly with my PC and "Firesi FRS-RACK" protection system througth Ethernet and UDP protocol. All data transfers(requests and respones) is OK.
When i run the same program on PXIe-8880 , i don't have a response. I tried change IP adress of PXIe-8880, but thats not a solution.
As you see, i made a new simple program with UDP squares and i still have no response.
What's wrong?
09-25-2018 03:46 AM
Are you able to ping the Firesi FRS-RACK from the PXIe 8880 controller?
What if you swap the cabling between the two Ethernet ports on the controller?
09-25-2018 08:00 AM
problem is solved,
thank you for message
09-25-2018 08:02 AM
The reason was about Firesi device, not PXI
