05-08-2018 11:35 AM
Need to stream data continuously from scope card to disk, sampling at 100M samples/sec. I think the PXIe-1071 chassis is capable, but what speed can the PXIe-8821 controller write data to disk?
05-25-2018 10:15 AM
it seems that it is 1,6Ghz, therefore you can do it!
06-27-2018 05:47 PM
Are the samples 8 bits or higher? If they are 8 bits, then 100 MS/s is 100MB/s. Otherwise it is 200MB/s.
Are you acquiring multiple channels? The numbers above need to be multiplied by the number of channels.
Are you using the disk in the PXIe-8821 controller? Did you order it with a hard drive or solid state drive?
06-27-2018 06:10 PM
16bit data, one channel at high speed, so greater than 200MB/s.
06-28-2018 09:15 AM
200MB/s likely cannot be done with the 2.5" SATA hard drive option. NI doesn't spec performance of the SSD, but the 250GB SSD option might be able to keep up.
06-28-2018 10:22 AM
That is my thinking too. Thanks.
