Yes you can use the IMAQdx drivers and acquire images with a PXIe-8135. The only limiting factor maybe whether or not you can use the high perforamnce ethernet drivers. If you cannot, you will have to limit the packet size to 1500. I am currently checking the specification on this and will post later what I have found out.
Greg H.
