10-28-2019 06:28 PM
I have a PXIe-8133 RT controller running Phar Lap 13.1. I have been trying to get my software to run as an exe and have been having issues, so I have switched to a very simple program that just turns on the User 1 LED to see if it is even running. The program runs fine from source, but it will not run as a startup exe. I have checked the DIP switch, have made sure it is set to run as startup, everything I can think of with no luck.
Anybody have ideas?
Solved! Go to Solution.
10-30-2019 02:12 PM - edited 10-30-2019 02:14 PM
Hey Ryan,
It's likely an unexpected BIOS setting. Try the steps listed in Real-Time PXI Startup Executable Is Not Starting After Reboot, listed below for convenience or if the above link ever breaks.
10-30-2019 02:24 PM
Thanks for your help Mike.B,
I overlooked the BIOS, I assumed the switch would override the BIOS. Never thought it would be in the BIOS settings!
Startup.rtexe is running fine now.
Ryan
