11-18-2021 06:15 AM
Hello everyone,
does the PXIe-6738 card have an overcurrent limit at 10mA or does the current need to be limited by me?
What needs to be considered, or what problems can occur with an overload?
Solved! Go to Solution.
11-18-2021 09:19 AM
There is no overcurrent limit described in the spec it is best to limit it externally.
From experience, these channels survived short to GND for a couple of hours.
11-18-2021 10:45 AM
Thank you for your reply.
So a charging of a MOSFET gate should not be a problem (apart from the fact that it takes a few microseconds)?
11-18-2021 02:49 PM
That should be fine, add a series resistor for safety, but why an AO to MOSFET gate? trying to characterize Vgs?
11-18-2021 11:49 PM
Yes a series resistor should be no problem. I want to measure the threshold voltage.
11-18-2021 11:57 PM
Fair enough, all the best!
