PXI
PXIe-6259 DAQmx module is not recognized by LabVIEW-RT
I have some problems due to my PXI system that has LabVIEW-RT doesn't recognize the PXIE-6259 data adquisition module but the controller is recognized. I have installed all the software. But my remote PXI system doesn't recognize the module.
The software that I can't install into the LabVIEW RT is the DAQmx software. I haven't the option to do this operation when I use the add software option.
Someone knows what I can done to use this module with LabVIEW Real Time??
Someone has experience with this module or another module and LabVIEW RT??
MAX VIEW
Best regards.
(4,824 Views)
Hi alarrucea,
the PXIe-6259 is supported under RTOS. In spite of the fact that you have installed the whole software in your PC, your PXIe-8130 controller might not have NI-DAQmx software installed on it. To fix it, follow next steps:
1.- Right click on Software under MAX >> Remote Systems >> LabVIEW-RT PXI system and select Add/Remove Software.
2.- Select Custom Install and NI-DAQmx driver in the drop down list.
3.- Install NI-DAQmx.
Once the PXI controller has rebooted, you should be able to find your 6259 board and your PXI system in MAX should looks like the attached screenshot.
I hope this helps!
Jesús
(4,771 Views)
