My PXIe-5413 does not appear in the list of resources on the VISA Options tab of NI-VSA software in NI MAX.
I have a PXIe-5413 function generator installed in a hybrid slot of a PXIe-1075 chassis connected to a Windows 7 PC. The PXIe-5413 appears under NI MAX’s Devices and Interfaces. I am able to communicate with the PXIe-5413 through the soft front panel and through NI FGEN sample code. The PXIe-5413 appears under NI MAX’s Devices and Interfaces with the LabVEW-FPGA icon which is a known issue. When I click on the name of the PXIe-5413 under Devices and Interfaces, in the Settings area it states that the PCI Device is 0. When I navigate to the Software > NI-VISA 16.0 branch of NI MAX, click on the VISA Options tab and look under Aliases, I do not see the PXIe-5413 listed under resources. Refreshing the list does not help. Originally, when I had version 16.01 of NI FGEN installed (webpage says that it supports the PXI-5413 but the read me section does not list it) the device did appear on the VISA Options tab. I’ve also tried installing NI FGEN 17.5 and then 18.5, NI MAX 17.5 and then 18.5. but the behavior is the same. I’ve manually added an alias with the bus and device number from the Settings tab but when I right click on that entry and select ‘Go To Resource’ it cannot find the PXIe-5413.
The ATE I am working on will use the NI-FGEN commands but I also need to be able to assign an alias to the instrument and create a VISA session. I assumed that the IO layer of the IVI compliant NI-FGEN driver is VISA compliant.
