02-12-2019 06:58 PM
All,
I have a system and I need 2 more Digital inputs. I would like to use the PFI 0 and PFI 1 of my PXIe-5122 to read a limit switch. With other devices you can read the current state of the PFI lines. I don't see a way to do this with the scope. I hope I am just missing something and it is simple. I could possibly trick the system by setting up a triggered acquisition. suing the desired PFI line then getting the status of the acquisition but I really would like to avoid this if possible. Is there some property I could read? Any Ideas?
Thanks for help.
MoparElwood
02-13-2019 05:21 PM
Hey MoparElwood,
I checked the NI High-Speed Digitizers manual and it states the following about PFI lines:
"Many NI high-speed digitizers have two digital lines that can import a trigger, import or export a reference clock, or output various signals."
The specification sheet also only discusses triggers and clocks.
http://www.ni.com/pdf/manuals/376937c.pdf
It sounds like the trigger is a good, if not the correct, approach to your situation. Why do you not want to go about the problem this way? Do you have other modules that you could use if you want to go about this a different way?
Best,
Ben
