I'm interested in using a PXIe-4492 module for measuring several inputs. Specifically, I would like to read in a signal from two accelerometers and six strain gauges. Since the module has 8 inputs, will it be capable of measuring each of these devices? What is the sampling rate of the module?
I am also looking into using a PXIe-4430 for measuring the voltages generated from the strain gauges (after the signals have been amplified). The PXIe-4430 has 8 channels as well. My understanding is that it should be able to read the signal from six different strain gauges, since there will be six input voltages and each of the strain gauges can be connected to a common ground. Is that correct?
