09-10-2019 01:06 AM
Hello. I would like to use the extended range pulsing function of the SMU NI-PXIe 4139.
I can't find any example on how to use this.
Any help would be very much appreciated.
09-23-2019 03:14 PM
You can use this(I think it is the same for previous versions of LV)
C:\Program Files\National Instruments\LabVIEW 2019\examples\instr\niDCPower\Single Point\NI-DCPower Single Source with Trig Meas.vi
This example - Demonstrates how to set up an SMU to use Single Point source mode, but use triggered measurements. Use this example to source a single voltage or current, and then monitor the output by measuring it using a trigger. Another device must be sending triggers to the specified input terminal for this example to work.
